tool rest height
CarvedTones
Andy
The lathe I just picked up didn't come with a tool rest. I am going to keep my eyes open for one, but in the mean time I will just make one. For turning small spindle work, I am thinking of a fixed height bar ever so slightly below center line (a tiny bit more than half the thickness of my skew, which is pretty much the only tool I will be using, so that I never have to tilt the tool down). Does that seem right? I used to turn a few years ago, but I wasn't that good at it and didn't get well schooled...
I don't want to repeat this trick...
:eek::elvis::eek:
CarvedTones
Andy
That was a few years ago before I got rid of the lousy lathe and tools I had at the time. It wasn't all bad:
That soft mahogany fooled me into thinking I knew what I was doing. The pear (in the previous picture) wasn't so accomodating...
Anyway, tool rest height comments?
toolman
Administrator
Chad
:eek::elvis::eek:
WOW our you ok? :eusa_naug Your height is about right, Not to low. :icon_sunn
FredP
Fred
That height would be fine for some stuff but adjustability is much better. different tools require different positions. :gar-Bi for hollowing a bowl I set the rest lower and for roughing a large spindle or outside of a bowl I set it higher. otherwise the bevel wont be rideing. thicker scrapers will need to be lower and larger gouges will need to be lower too. I have a home made rest that came with an old delta that Im not useing. I also have a short rest that fits it. I cut the larger rest up to make somethig else. you are welcome to them if you like. the lathe they were made for is an old delta with an 11 or 12" swing if I recall. PM me if you want em.
