Thanksgiving Dining Room Table
woodnick
Nick
Finished just in time for Thanksgiving dinner.
Some of you may recognize this as the piece of Kiatt that was leaning against the wall at East Wake Hardwoods for a long time. I finally convinced my wife that it would make a better dining table than a prop for Roger's wall.
We had Mike Smith cut it to 18" wide, parallel to the straightest edge. This did two things: first, it enabled us to put it through Roger's 24" planer, and also it was narrow enough for Mike to cut it in half so I could book match the two halves. This then made a 36" wide table. I put butterflies across all the checks so as not to waste any of the length. I wound up with a table 36"x 103". This will give everyone plenty of elbow room at the table for Thanksgiving.
woodnick
woodnick
Nick
Thanks! I brushed on 6 coats of DEFT Lacquer, sanding after everyother coat. Then wet sanded with 800 grit and then buffed with 3M Finesse-it.
Awesome table from what I can see....I really wish you could post bigger pictures, I would really like to see the detail. Finished just in time too :eusa_clap:eusa_clap:eusa_clap
Never mind, I found a bigger pic in your album, yes, it is awesome
woodnick
woodnick
Nick
It's a trestle design made with poplar, painted sage green to match room decor. It will soon be sitting on a new hardwood floor.
dozer
I remember that piece of wood. I just left from up at Rogers place. You did a fine job on the table and made great use out of that piece of wood.
cpowell
Chuck
Hey, I also remember that plank. You really did the beauty of the wood justice. Nice craftsmanship and a beautiful finish. :eusa_clap :eusa_clap
Chuck
jeff...
User not found
Who wouldn't like a slab table? Very nice indeed :icon_thum
sapwood
Roger
Nick, that makes for fine dining :icon_thum
It looks great and should be around for many more Thanksgivings.
Roger
User not found
Beautiful job and well thought out! Happy Thanksgiving!
