Tapering table legs on bench jointer
rusty
Rusty
Have a 8" cutech bench jointer, carbide teeth, and works very well.
Working on a table with 3 1/2" square legs 29" long, and want to taper two sides down to 2" at bottom of feet.
Taper will start 7" from top of leg. watched a couple of utube videos already.
looking for more info before I start. any ideas
FredP
Fred
I taper legs on the table saw with a shop built jig then clean up with the jointer.
Joe Scharle
I doubt you have sufficient infeed/outfeed table length on which to mount stops, but you might try it freehand on scrap. But like Fred says, it's such an easy, one pass effort with a tapering jig on the tablesaw. Use a jig like these:
rusty
Rusty
Tapering a 3 1/2" square leg on a 10" craftsman table saw is iffy in my opinion. I normally taper flat stock with a taper jig on my TS if it is not too thick. just looking for alternatives.
Dave Richards
Dave
Another alternative would be to do the tapering with a sled and your planer. You can rough out the legs at the bandsaw and finish them at the planer. A benefit to doing this is you can do at least two if not three or four legs at once depending on the width of your planer.
FredP
Fred
Didn't catch the 3 1/2" thickness. Bandsaw would be my next choice. Same jig;)
Joe Scharle
Well next then I'd attach a long fence to the jointer and clamp on a stop. I've this method when I only had a Shopsmith.
TENdriver
TENdriver
Rusty,
for me, removing 1.5” of material on the jointer is a stretch. I agree with Dave, that removing the waste with a bandsaw is preferable, though I probably would use the tablesaw in two passes from opposing sides.
Agree with Tendriver, remove most of the waste get within 18-1/4 then finish off with joiner, faster easier and you will more predictable results.
Rusty,
rusty
Rusty
Don't have a bandsaw, and that humungas hand plane hurts my whole body just looking at it....
Time for a new toy, bench bandsaw with a decent fence should do it, I can make a taper jig for it.
Any suggestions?
Dave Richards
Dave
Any suggestions?
Simple one. A piece of 1/4" Masonite or MDF a little longer than the legs. Glue or screw blocks to it to hold the leg at the right angle. Use the rip fence as a guide. I could make a drawing for you if you need it.
rusty
Rusty
that will make a nice taper jig.
What is a decent benchtop bandsaw that has a good fence?
Dave Richards
Dave
I guess I can't recommend a benchtop bandsaw. I haven't looked at them for years. Whichever one you choose, make sure you get an appropriate blade for the task. Don't get one with a lot of teeth per inch at least for cutting these legs.
Chris C
Any suggestions?
You'd be amazed at how easy that big plane is to use. Mike Davis is holding a class in April on the most important hand plane skill of all.....sharpening. It makes all the difference.
