Curtis, I found a very simple one that I'll try to describe but can also take some pics later. It's a couple 2x4's with a barn door hinge. For the horizontal surface, screw a thin enough piece to the end of the horizontal so that it will slide down into the groove on the front rail of your TS. Make everything so the horizontal piece is level or very slightly proud of the TS surface. Screw the hinge to the farthest end of the horizontal then add a leg screwed to the hinge to the floor. When not in use, the horizontal and vertical pieces fold together for easy storage. I have two and this make easy work to set a 4x8 sheet of plywood on when breaking down full sheets. I hope this is all understood. If not, let me know and I can add some pics.
