Thanks for asking… blade needs to be cleaned. It’s sharp and straight, but needs cleaning.In rereading all this I don’t see any mention of the quality and condition of the blade.
How long since it was cleaned? Sharpened? Replaced?
Thanks for this note and the other two. I will take a look at the nut and flanges. Maybe there is some contribution to the issue there. I do use a machined disc to support/stabilize the blade, though. But, after all the comments here, I see that I have some further investigation and cleaning to do. And, I also need to consider the nature of the tool and its inherent limitations. Its a nice contractor saw, but not a cabinet saw. Given that, I recognize that there is a point of diminishing return and that I may already be near to it. LOL!Not saying this is the case;
Going from punched/pressed* arbor flanges to machined, can tighten certain cut issues. It effects hysteresis,or noise in the system. Understand,this is a rabbit hole... can be a good hole though. From there( machined flanges) you'll enter into balancing assemblies. Meaning,next level flanges have a way to balance the complete blade/flange "assembly". The backdoor approach is with a VFD.... you can tune out "some" vibration frequencies.
*Pressed; on punched flanges,the centers can be formed in presses for the,offset.
Agreed. And I was able to set the fence exactly as you suggest. Runout on the blade seems be about 0.003. Overall, I’m pleased and happy..003 is well within tolerances for a table saw.
I like to set the fence .003 wider at the back of the blade. I believe this helps with marks due to blade runout.
That said, check your blades for runout and you'll probably be surprised. It doesn't affect anything, just makes a wider kerf.
