I'm trying to crosscut 1 1/2" thick by 4 1/2" wide ash on my table saw, but I'm getting uneven cuts. The cut profile is more or less convex, with the leading and trailing edge cut deeper and the middle of the cut proud. The difference is about 0.005-0.006" on a piece that I just cut. Is this blade deflection - somthing that using a "better" blade would cure? I'm using the factory blade that came with my Steel City table saw. It's a 40 tooth carbide ATB blade. The blade is clean and looks like it is within 0.001" of spinning true at the teeth. It does appear to be cupped though. If I put my 6" engineer's sqaure on one face, I get a gap on each end. If I rock the square all the way to one side, the gap is about .008". I'm crosscutting using a home made crosscut sled that has 120 grit sandpaper glued on the face of the fence to prevent slippage. I've also tried using a small bar clamp to hold the wood in place. There is NO slippage against the fence and the sled runners are snug in the slots. The fence appears to be square to the saw blade using the engineer's square. When I cut 3/4" hardwood plywood using the same setup, the cut is just about perfect with no detectable variation. I would appreciate advice on this before I rush out to just buy a new blade. Thanks!
