T track clamp
Rwe2156
DrBob
I've been looking for a while and finally found these. All the others I found only work with a plate.
5/16 T track bolt fits right in it!
187767
187768
zapdafish
I used the same method with my first bench, unfortunately over time the track started coming out and/or getting bent if I used to much force to hold things down. I even drilled extra holes to try and keep it down.
kserdar
If the track is pulling out. Don't use screws, use bolts with fender washers on the under side. My bolts are 3-6" apart depending on location/use of certain areas.
