Surfacing Strips For Bent Lamination
Wiley's Woodworks
Wiley
I'm getting ready to cut 10 3.5" wide white oak strips for a glue-up lamination. They will make curved legs for a wall shelf box. My ?: Do I need to surface sand the laminations or can I go straight to glue-up after resawing the strips on my band saw. I get reasonably clean surfaces with the band saw.
cyclopentadiene
Best to resurface and keep in the same order. Plastic resin glue has a much longer open time and allows time to get all the surfaces covered and get all the clamps placed.
bob vaughan
Bob Vaughan
Excellent advise. Plus the plastic resin glue doesn't have the tendency to cold flow over time like PVA (Titebond, etc.) glues will.
If you do not have a drum sander, I'd recommend that you lay the strips side by side and sand them as a group to insure equal sanding and to avoid rounding any of the edges.
bob vaughan
Bob Vaughan
I think those little slow-feeding high RPM surface planers with sharp knives will do nicely. I've used them for that before and they put a nice finish on the wood ready for glue.
I guess another thing that should go without saying is lots of very strong clamps.
