I think Dennis has given really good suggestions. A hollow core door will weigh less than a piece of 3/4 plywood. It is not very hard to remove the plywood skin from a piece cut off so you can glue it with construction adhesive back into the remaining piece of door - I have done it. Or you could make a piece for the edge from scrap. The advantages of this approach are weight, stiffness, and cost. Should look decent too. If all your source has are pre-drilled ones you could get a wider door to get a clear piece wide enough.
I think that will work without further stiffening but, if not, a leg of 3/4 inch wood between the machines should make it plenty stiff for clothes folding. It wouldn't even have to be fastened, just cut to length and resting between the machines.
If you really want to get scientific you can calculate the deflection of various alternatives, the equations are available on-line. Experience says a cheap interior door best fits your criteria, however.
