So I've used wipe on poly on top of danish oil with walnut tons of times and have always had good results. So I'm really baffled as to what has gone wrong, and hope maybe some of you can put in your ideas.
I used Watco Danish oil on walnut that was sanded to 220. Used two very light coats and rubbed it down after. It felt nice and dry - I gave it 3 + days to dry more before I put the minwax wipe on poly. I mixed about 50/50 the satin with the gloss, and shook up both containers before I mixed. Mixed in a plastic cup, and stirred for a few. ..proceeded to rub it on and all went well. I was going to do a second coat later that night, but time got away from me. I went out about 6 hours after the first coat to find it still tacky. It has been humid, but my shop is temp controlled. I waited till morning and still tacky. Now a day later and I've put this piece on the lathe and taken a cloth to it to try and buff out the tackiness... Seemed to help some. Brought the drum inside where it's been for a good 5 hours now and still feels like it's oily/dirty. Not really tacky, but not the way it should feel.
Another piece of info is that I inset a section of a different wood after I put danish oil on the main section. so no danish oil on this inset maple. it's sticky as well. Both cans of the poly are less then 3 months old and been stored in temp controlled shop.
Should I not have shaken it up? I seem to remember mixing them before... is this a no-no? I used what I had left of the mixture and wiped on a bit to some scraps of different woods in the shop. I'll know in the AM if it's the mixture. But I would think it's OK to mix? I just wanted something with a bit more gloss than satin, but not as glossy as the gloss
Suggestions and / or advice is welcomed!
