So I happened to come into a Stanley No. 62 for a price that was really hard to pass on. There are however a few problems with the plane, while I'm not afraid of doing some work to get this thing back up and running, at some point I question is it worth it? Even though this is not what I would consider collectors grade I would prefer to keep as many original parts as possible. Final stipulation is I told the seller I am going to put all the items purchased from him back to work and I will not be re-selling just to make a profit. So in an effort to stay true to my word it's either repair it or bust.
Problems:
1) The mouth does not adjust. When the knob is removed the adjustable mouth plate does come out and is only tight at the front of the plane. I think some judicious filing can fix this.
2) The blade needs to be replaced. You can see the previous owner got their money's worth out of the original. What if any currently made blades will fit this?
3) The japanning is bad shape. Really not a big deal since I'm out about to get the ugly stuff.
4) The handle bolt threads are badly stripped out in the body of the plane. I've tried a handle bolt from another plane and got the same result. I'm toying with the idea of brazing to fill the hole and re-tapping OR filling with JB Weld and re-tapping. Either way I would have to buy a 12-20 bottom tap. Also, there is a little hole in the bottom of the plane where someone ran the bolt in too far and blew out a little iron plug. Any thoughts or past experiences anybody can share?
5) The mouth is broken behind the blade. I understand this normal for these planes but will it affect the operation? If there are newer blades that are thicker, would that alleviate blade chatter due to the lack of rearward mouth support? Perhaps running a bead of brazing across the mouth and use a thicker blade.
Problems:
