So I was jointing a large block of wood that I glued up from smaller pieces and noticed that the block did not come out square. The dimension of the wood is about 5 7/8 x 5 1/2 x 11. I jointed the two sides that would fit my jointer and each side is flat when placed on the jointer bed. I checked for square and its off. See attached images. I check the fence on the jointer and noticed it not being square to the table. Could the fence not being square to the bed be the issue? I have since squared the fence (Best I can possibly do) and glued up some construction lumber to similar dimensions. Thoughts.
I Will test on the lumber in a bit when it fully dries.
NOTE: I have passed close to 100 bf through the jointer with no squaring issue. Most of the lumber barely reaching 3 inches in height. Think of the majority of lumber being passed along the jointer for cutting boards, crates, and etc.
Type of Jointer is a Jet 6in HH floor model.
