Reply to: sale-909402641@craigslist.org [?]
Date: 2008-11-10, 2:23PM EST
This model includes :
• 5" x 16" extruded aluminum drum, self-cooling, precision machined and balanced
• Drum operates at 1725 RPM
• Continuous duty motor offers the advantages of heavier use for longer periods of time.
• Precision flattened reinforced steel conveyor bed
• "No-give" power feed conveyor belt.
• TensionRollers, zinc-plated steel infeed and outfeed rollers mount next to the drum. Height and downward pressure are adjustable
• 1/16" per turn height adjustment
• Height adjustment handle allows radical height changes, while also allowing minute adjustments for extremely precise sanding thickness control
• An infinitely-variable feed rate of 0-10 feet per minute for surface, dimension, and finish sanding
• Mandatory dust collection for all models. 400-600 CFM recommended
• Minimal assembly required
• Drum ball bearings are sealed and permanently lubricated
Standard Equipment
• One abrasive strip, 80 grit
• One 100 grit abrasive conveyor belt
• TufTool
• Trackers
• Metal stand with shelf
• One box of ready-to-wrap abrasives
• 4" dust port
Sanding Capacity
Maximum Width (in): 32
Minimum Length in): 2-1/4
Maximum Thickness (in): 3
Minimum Thickness (in): 1/32
Dimensions (HxWxD/in): 18 x 23 x 32
Drum (in): 5 x 16 extruded aluminum
Drum Speed (RPM): 1725
Drum Bearings (in): 1" (2 quantity)
Dust Cover
(plastic, diameter/in): 4 diameter dust port for use with dust collector 43 in.-lb torque, direct drive D.C. motor, Infinitely variable feed rate of 0-10'/min
Motor (TEFC): 1-1/2 HP, 1700 RPM, 110-120C, 60 Hz, 14 amp, 1 Ph continuous-duty, overload protection
Additional Accessories include: Casters, In & outfeed table extensions, and a "poly" drive belt. These accessories alone are valued @ over $300.00. Please see attached pictures. Call 704-246-7205.
http://charlotte.craigslist.org/tls/909402641.html
As usual, Not mine, no one I know.
Standard Equipment
• TufTool
• Trackers
• 4" dust port
Sanding Capacity
Dust Cover
- it's NOT ok to contact this poster with services or other commercial interests
