Quick, look away if you seek fine woodworking. This is shop furniture - primitive and functional working tables. A couple years ago a Raleigh lumberyard offered 10’ 4x6 SYP timbers for dirt cheap. Being of the frugal sort I picked up a load and stickered them in my shop for a couple of years of drying and warping, with the plan to make some heavy-duty work tables. These are center-cut construction grade timbers, prone to cracking, checking, warping, twisting and moving in just about any undesirable way that wood can move. Except buckling- these things are strong and heavy and even with their multiple defects end up making some very stout tables:
Tops are about 2.5 feet deep and 8 feet wide, finished with boiled linseed oil, wax and oil-based poly. Bases have water-based poly left over from the flooring finish. Legs and short stretchers are also 4x6s, long stretchers are 5/4 SYP from Lowes. I experimented with various configurations of half-lapping stretchers, but all are face screwed. Scraps of leftover flooring ¾” ply fill in for the shelves.
Tops ended up just under 3 inches thick and were too heavy for me to handle / flatten as a single piece, so I glued pairs together and then used four 3/8” threaded rods to hold them together. You can see that one of the lengths is pieced from cutoffs glued together end to end with biscuits and held tight during glue-up with pinch dogs. This is an unconventional and labor intensive way to use scrap. Since the cutoff section is sandwiched with full-length boards I don’t expect any failures, but I doubt that it was worth the time unless you find the joy in cheap.
Stock was thickness planed in a DeWalt lunchbox. I don’t have a jointer so I built a sled for edge jointing. When the tops were secured with threaded rod there were no gaps but some differences in height and flatness, which I took out with hand planes. SYP is a bear to plane - in this case doubly so because of knots, varying densities and my inattention to grain direction during assembly – but the final results turned out good enough for shop worktables, nonetheless.
And for the stealth gloat: it’s a trip down memory lane. My dad was a patternmaker, and growing up I would spend time in the shop, often fiddling with his vise. When dad died I didn’t have a workshop so we sold his tools in an estate sale. I talked an uncle into taking the vise as something special; years later as he's getting out of woodworking it returned my way. Hmmm, that thing is heavy, it would definitely need a solid bench:
The evil internet tempted with some pictures of flush-mounted Emmert vises, so in the ongoing spirit of overkill I had to try that. Bad idea, adding unnecessary complexity and work. Not worth it, and that’s even before I pinch my finger twisting or turning the vise. I completely disassembled the vise for cleaning and lube, which made the installation somewhat easier. It's in great working condition, complete except for one broken dog. Looking closely, I think it sports a period-correct 1960’s broom handle for its handle. I’ll keep it, a nice reminder of my father’s cheap and practical repair. Reflecting on the Emmert, it’s a nice vise, but I’ll probably find myself spending more time staring at it and thinking of my dad’s shop than I’ll actually spend using it.
Chapel Hill
Chapel Hill
