Shop Fox 3HP cyclone dust collector, model W1809. Lightly used in a hobby workshop. This model has been discontinued, this Shop Fox version is similar to the Grizzly G0441
Full specifications here -> - Woodstock International Inc.
Motor
Type.............................................................................................................. TEFC Class “F"
Horsepower................................................................................................................. 3 HP
Phase/Voltage ............................................................................................. Single-Phase/220V
Amps .......................................................................................................................... 22A
Cycle/RPM ................................................................................................ 60 Hertz/3450 RPM
Switch .......................................................................... Magnetic w/Thermal Overload Protection
Bearings ............................................................................... Shielded & Permanently Lubricated
Overall Dimensions
Length ......................................................................................................................... 62"
Width .......................................................................................................................... 39"
Height ........................................................................................................................109" (this thing is tall!)
Footprint ............................................................................................................... 62" x 39"
Box 1 (Cyclone) Size........................................................................................ 54" x 28" x 331 ⁄2"
Box 1 Shipping Weight ................................................................................................ 353 lbs.
Box 2 (Cartridge Filter) Size .............................................................................. 61" x 211 ⁄2" x 22"
Box 2 Shipping Weight ..................................................................................................51 lbs.
Box 3 (Stand) Box Size .................................................................................. 43" x 131 ⁄2" x 81 ⁄2"
Box 3 Shipping Weight ................................................................................................ 121 lbs.
Machine Weight With Stand .......................................................................................... 467 lbs.
Machine Specifications
Maximum CFM (8" Pipe, w/Filter Installed) .........................................................1654 CFM @ 2.3" SP
Maximum Static Pressure ............................................................................................... 14.33"
Impeller Size...............................................................................................................151 ⁄2"
Intake Hole Size............................................................................................................... 8"
Cartridge Filter Diameter ............................................................................................... 201 ⁄8"
Cartridge Filter Surface Area ..................................................................................... 113 sq. ft.
Cartridge Filter Capability .............................................................. 99.9% of 0.2~2 Micron Particles Collection
Drum Size ............................................................................................... 55 Gallons
Sound Level................................................................................................................ 84 dB
Construction
Cyclone Body .................................................................................................. 16 Gauge Steel
Radial Impeller................................................................................................. Steel, Riveted
Collection Drum............................................................................................................Steel
Cartridge Filter..........................................................................................Spun-Bond Polyester
Blower Housing................................................................................................ 11 Gauge Steel
Stand............................................................................................................ 14 Gauge Steel
Additional Features
Reinforced Intake
55 Gallon Collection Drum with Bag Holder and Plastic Collection Bag
Gentle Brush Cleaning Mechanism Inside Cartridge Filter
Remote Control w/Programmable Timer
Casters Mounted on Collection Drum for Easy Moving
I will be happy to assist with the disassembly of the dust collector and loading it, but moving some of the parts would be best with three people. The dust collector is located in my walk out basement, so there are no conventional stairs but there are some shallow steps to navigate.
I'm located in North Raleigh.
Motor
Overall Dimensions
Construction
Additional Features
Reinforced Intake
