Project w/ Pics Shop Doors
creasman
I’ve shared with some of you that my wife and I are building a new house. As part of this I will have a detached workshop. My goal is to do many of the tasks myself where it makes sense. This led me to build the doors for my workshop. I already had most of the materials. It’s a way to save a few hundred dollars.
There are two doors. They are traditional six-panel doors. Each is 36” wide by 96” tall and 1-3/4” thick. The main door will have the two center panels as glass rather than wood. For the wood I chose reclaimed chestnut. I have a supply of this that I saved from a house I took down as a teenager. My best guess is the lumber was milled around 100-150 years ago. It’s also wormy to add a bit of character.
I’ve made a few doors over the years. The first and most important goal is that they be absolutely flat when finished. For panel doors this means all parts, especially the stiles, must be straight and free of any bow, twist or warp. I could have made these from solid chestnut, but you’ll find most large doors have stiles that are laminated. Lamination of several layers yields a straight and true core. You can then veneer a skin over this core using the best wood. I used Titebond III for all the joints since it is waterproof and these are exterior doors.
The core of my stiles is made from heart pine that I salvaged from an old house that once stood where we are building. I milled this down to about 3/4” thick and laminated the planks. While gluing I clamp to my assembly table. This table is made to be flat and true just for applications like this. I check the work at every stage for any bow or warp and arrange them so that the stresses are countered as they are glued. The results of the first glue-up are sawn, planed, jointed, and then stacked to increase the layers.
After the core of pine is built up, the end layers of chestnut are added. Lastly, a 1/8” thick skin of chestnut is added to each stile. This means you only see chestnut. The end result is stiles that are straight and true, ready to be mortised for the rails.
Most of the mortising work was done at the drill press to remove the bulk of the waste. I tuned the fence to make sure it was perpendicular with the table and clamped the work while drilling.
A wide flat paring chisel and a scrap board planed to the right thickness makes it easy to remove the remaining waste. It helps to have a block the thickness of a tenon to test the fit as you go along. These are deep mortises and extend to within an inch of the other side in order to accept 4” tenons. I could have squared the ends of each mortise, but it’s less work to round the tenons instead.
The last steps on the stiles are to cut a dado the length of each on the panel side and then add moulded edges. I chose a basic ovolo with a filet. The groove is the same width as the tenons and is for the raised panels or glass panes. The ovolo is removed where the rails intersect. More on this part later.
The rails and mullions are all glued up from 7/8” stock. The mullions attach to the rails with a comparatively short tenon, only about 1-1/2”. Anywhere a rail meets a stile, or mullion meets rail, I coped the moulding to give a mitered look. By coping the end which has the tenon you account for any movement of the wood. Where a mitered joint might open up over time a coped joint will maintain the desired fit. This is the process I followed.
The first step was to make a guide that fits over the part with a true 45 degree angle. This is clamped in position and a paring chisel is used to miter each moulding on the tenon ends. This angle provides the perfect curve to follow when coping.
How you remove the waste is a matter of preference. I found it easiest to first undercut in part and use a straight chisel up to the curve. From there I used a 5/16” incannel gouge to remove the remainder up to the curve.
Removing the waste on the mortise side is much coarser. After using a backsaw to cut through the ovolo I used a chisel to remove the moulded section down to the fillet. A paring chisel is all that’s necessary. When the mortise and tenon ends are joined you have a perfect fit that will stay together.
This is a good project to build coping skills. All together in both doors there are almost a hundred coped joints. Before doing any work on the panels I marked and fit each joint, then assembled the entire frame. I don’t like surprises once the glue starts flowing.
I’ll repeat the dry assembly one more time after the panels are complete. Note the little dots of blue painters tape. This is my way of remembering how they go together. The outside is marked with tape and the tape is always top and right side. I find this visual aid a quick way to position the part once I start gluing.
My goal is for the panels to remain stable. These are 1-5/8” thick and would certainly expand and contract if solid, so I composed them in layers. The center layer is 1/2” marine grade baltic birch plywood for extra stability. On each side of this I glued a 7/16” layer of chestnut. Finally, a 1/8” skin of hand picked chestnut boards were added. These were all part of the same flitch so that I could book match the grain on each pair of panels. Overall, this gives the door a more balanced look. These were glued inside a vacuum bag to maintain flatness.
I did the final assembly in the garage. There just isn’t room in my shop for this sort of build. To maintain flatness I placed a sheet of melamine over 2x4’s on sawhorses and made sure these were level. It took my son and I about 20-25 minutes to glue, assemble and clamp each door. Any longer and the glue begins to tack.
I chose ProLuxe Door & Window Wood Finish for the doors. I haven’t used this product before, but it gets high marks. These are exterior doors and need as much UV protection as possible. This product seemed like a good compromise, offering good protection without hiding the wood under a heavy stain. I’m using the dark oak color. Each side gets three coats, lightly sanding in between.
As always, thanks for looking. I’ll post some more pictures once I get them installed.
Wilsoncb
Williemakeit
Door looks great! As usual, nice work and write up. It makes me realize how much work actually goes into a door like that.
JNCarr
Outstanding craftsmanship as usual. Dead-on on all the decisions regarding stability. NICE!
The writeup is superb.
pop-pop
Man with many vises & whackers
First, really impressive work!
Moulding planes for the all the grooves and ovolo?
I also prefer C-clamps when I need serious clamping. Were some of those in that bucket of clamps?
Never thought of paring mortise cheeks on the flat with a guide like you did. Makes perfect sense and has to be much more accurate.
Martin Roper
Martin
The wood may be more than a century old, but that door looks like it'll hold up for a couple centuries at least.
creasman
creasman
Thanks all for the kind words. I have a Lie-Nielsen butt mortise plane arriving today to help with installing the hinges. Hoping to get both doors installed over the next week or so. I made the jambs from treated deck boards and have these already in place.
@pop-pop, in answer to your question, I did not use any moulding planes on this project. I have so much going on with building the house there just wasn't time. I used a 7/16" round over bit on the router table. The groove was done with dado blades on the table saw. And, yes, many of the C-clamps are ones that came from that bucket I picked up at the estate sale you and I were at. Really glad I found those!
Stuart Kent
Stuart
View attachment 244222 View attachment 244223
View attachment 244224 View attachment 244225
View attachment 244226 View attachment 244227
View attachment 244228 View attachment 244229
View attachment 244231 View attachment 244232 View attachment 244233
View attachment 244234 View attachment 244235 View attachment 244236
View attachment 244238 View attachment 244239
View attachment 244241 View attachment 244242 View attachment 244243
well done Jim! Beautiful work.
Mike Wilkins
That is a masterful build. I have been experimenting with making doors for my own shop using traditional mortise and tenon construction. Mine are simple Shaker style with grooved panels made from some old pine lumber. I will have to explore the stave core method when I make the main shop door; and the loose tenon method will simplify construction.
CharlieGator
Charlie
I always greatly appreciate posts with pictures and narrative/explanation!!!
These are extremely helpful and a great resource to learn from increase my skills!!
drw
Donn
Jim, I always enjoyed your posts and I will typically read through them at least twice (there are too many nuggets of great information and insights to risk missing anything). While many people may think a "door is a door", but in the hands of a true craftsman a door can be a well-engineered work-of-art! Thank you for sharing this project with us!
creasman
creasman
Can't wait to see the house door if that is for a shop
Interesting you should make that comment. I was originally going to make the front door for our house, but decided to purchase one instead. I'll be making the cabinets and doing the trim work. I questioned whether I would have the time to make the door as well. It is an arched door, so a bit more work is required. I did save by opting to do the finish myself.
