Whenever I read about sharpening chisels - they suggest the use of a magic marker on the chisel so you can see where the grinding wheel is removing the metal. You adjust until you have full coverage - and then grind away, replicating the angle.
So what do you do when you've (me especially) ruined the original angle? I do have an angle gauge (see picture below). Is it as simple as grinding the chisel until it fits into the 25 degree slot??
Thanks,
Roy
Thanks,
Roy
