I borrowed a digital microscope from work and made a few pics this morning. This is a Klotzli chip carving knife at around 100x or so. The magnification is not real accurate on the small handheld unit. Later I may try to use one of the lab scopes for some better pics. This should give a rough idea of a simple quick sharpening job.
This is the rough edge after I tapped it with a screwdriver.
Here I've reshaped the edge on a 320 grit diamond plate. You can see the wire edge formed where two flat planes meet.
Here you can see the wire edge from the opposite side.
Here I have stropped the blade on a piece of leather with green polishing compound.
You can still see grind marks from the 600 grit diamond, but this is more than sharp enough to carve with.
Here is some tissue that cut with this blade.
