I am currently on "light duty (lift no more than 5 lbs) with 4 more weeks of a 6 week sentence. So, to occupy myself, I have started going through my inventory of cutting tools with the objective of getting them sharp and ship-shape. In doing so, I realize that I do not have a basic machine that resides in most shops and garages: Namely a bench grinder. It would surely speed up the preliminary steps in the sharpening process.
I do have a 1" belt sander that also has a small grinding wheel on it, but the rest is atrocious and the small diameter is a bit extreme. I also have an old Delta wet grinder (very slow speed) that is impossible to get a decent wheel for, as well as it is so slow that it can do it by hand faster.
So, with a month before I could even put a new grinder into service, decided I would ask about which ones people have had the best experience with. It will mainly be used for establishing primary bevels and shape, as well as sharpening and dressing edges for brush cutting tools, shovels,etc. as well as the other side would most likely hold a felt wheel most of the time.
I am thinking a variable or dual speed, 8" diameter one with a solid adjustable rest would fill the bill. A rest configuration that would allow me to use various sharpening jigs would be a big plus.
Is 8" a good diameter?
What RPM range would be best?
Which ones to stay away from do to poor bearings and excessive ply in the shaft.
Or would I be better suited with a stationary belt sander? If so, what size belts would be most efficient.
Thoughts, please
Thoughts, please
