Current shop project is the ShopNotes / Woodsmith router lift. It was originally published in ShopNotes issue 121. Steve Ramsey has a good video of his build, plus Woodsmith also has a video on You Tube. One the items of the build is the channels that the lift rides in. Shown is using table saw to cut a V groove, plus chamfer on edge of other side of guides. Not an easy task if your saw isn't EXACTLY at 45. But using the "V" grooving cutters in Sears molding head, it's an easy task. Because the same cutter is used to cut both pieces, they are a perfect match. No sanding is needed to remove blade marks. So I give the Sears molding head, that several are afraid of, a big YEAH! Yes it's loud, but so is my planer and jointer.
