I usually use a scrub plane for the first step on rough lumber to remove enough high spots so that I can feed the board thru the planer often skipping the jointer until this week.
As a rule, I scrub-plane across the grain as suggested by many others in the past. This gets the job done quickly but sometimes leaves a rough surface.
The video suggested by Dan (@danmart77) shows Phil Lowe using his scrub plane along the grain. This leaves a fairly smooth scalloped surface.
Tuesday evening during his presentation to Triangle Woodworkers Association, Jim (@creasman) demonstrated his scrub plane usage diagonally across the grain suggesting less tearout that way.
How do others use their scrub planes and why?
