Scroll saw blade`
I'd like to find a "spiral" scroll saw blade that is at least 5 1/8" long to go in a new Infinity tools fret saw. Longer is fine too but less than 5 1/8" won't work.
TIA
Phil S
Phil Soper
I have the same saw, it is great. I mostly use Pegas blades from Switzerland. I just measured them - they are 5 1/8.
I have many spiral blades and you are welcome to a few dozen.
5 1/8" l is what came with the fret saw. I guess it's a Pegas which is what Infinity sells on their site. The fret saw instructions say "the standard length for a jewelers/fret saw blades is 5 1/8". Blades that are shorter than standard will not work. If the blades are too long, use wire cutters to shorten the blades."
I cannot find a spiral blade from Pegas that will work in my new fret saw so I could use a longer blade and cut it to the 5 1/8" length.
Berta
Berta
Scroll saw blades are 5 1/8. I just measured my Flying Dutchman spirals. 5 1/8.
I am one of the few that dislike Pegas blades.
The Flying Dutchman blades that I looked at are 5" not 5 1/8". I ended up buying 6" Pegas blades and snipping a little bit off to get the 5 1/8" needed for my Infinity fret saw. Thanks for checking though.
