Went out to use my sawstop table saw this morning. First cut went fine with the lights going through the startup routine. Blade started and I made my cut. Moved the fence and got setup for another cut. Turned on the switch and the lights went through the same startup process. Pulled out the paddle and it just made a relay like sound and the red light is on solid with a fast blink green. I tried my dado stop block to see if it might be that but it does the same thing. Anyone have a sawstop and had starting problems ?
Looks like the breaker is tripping each time n the side of the switch box.
