Sander replacement pads
sandmander12
Johnboy
I have two older rectangular pad sanders. Both app 4x8". any recommendations on replacements...foam, rubber, felt,etc ??? If so,what's best and where to get it. Thx.
Check out generic amazon pads, remember, look at the screw hole attachment get one close enough or exact. If it is not one close will allow you to add a hole on the pad to attach. Then, get a facing pad to go over it. These wear out 1st protecting the pad attached to the machine.
I have adapted a few over the years they all work and still today. Easy.
ChemE75
Tom
FWIW, on my old delta half sheet sander, pad was beat up and dried out. After unscrewing it from the sander I scraped it off the backing plate, cleaned off the old glue and then cut an old mouse pad to glue on. Kind of a dense foam rubber with a fabric facing that by chance I found psa paper sticks and peels off cleanly. Can’t recall brand, but it was a contact cement I used to adhere it to the backing plate. Drilled through the backing plate holes, used a razor cutter to clean up the holes through the pad and screwed it back on. It’s not a sander I use often but pad has held up well. I’m actually thinking to do same for my newish dewalt 1/4 sheet sander.
