My operation:
Cut the stock to rough length using either the miter saw or the circular saw (or even a hand saw...). I'll generally leave each piece ~2" oversided. Shorter boards are much, much easier to work with when you have modest tools.
If the board is narrow enough for the jointer, I start by jointing one face. I generally select the concave side down, so that I have two points of support (convex side down would rock). Then, using the freshly jointed face against the fence, I joint one edge. The stock is now S2S.
I plane the opposing face until its flat, and get the stock S3S. If I took a lot off the opposing face, I take some off the jointed face as well to prevent warpage. I usually leave the boards a little oversized and stop at this point, to let the wood re-acclimate. After re-acclimating, I check to make sure things are still flat and square. Sometimes, a touch-up on the jointer is needed. I then plane it to final thickness.
To get the final side straight, I rip the board on the table saw with the jointed edge against the fence. The stock is now flat & square.
If the board is too wide for the jointer, but is reasonably flat, I'll joint one edge, then rip it to width on the table saw, using the jointed edge against the table saw fence. I then basically repeat the procedure. The jointed edge will be re-jointed a bit to make it 90 degrees to the face.
If the board is too wide and is twisted, bowed, cupped, wavy or otherwise unjointable, I hot glue it to a piece of MDF with one edge sticking out, and rip the edge straight on the table saw. Then rip it to width. If it's important to keep the board intact, I'll crosscut it to rough length and joint it using the planer and a sled.
If I ever have a board that's wider than 12", I'll call Travis
