I am looking for their two part clear finish. Not oil.
Folks across the pond have been recommending Rustins clear to do my dashboard
Not an oil. two part. suitable for direct sun. Thick build. I was almost thinking bar-top, but it self levels and don;t know if it can be sprayed in 6 or 8 coats.
Plastic Coating & Hardener Gloss | Rustins
Two-part clear cold cure lacquer for use on wood, hardboard, cork and plastic laminates. Extremely good adhesion, resistant to heat, solvents and...www.rustins.ltd
Yes, or like virtually all British cars. This is a 73 Triumph Stag. I may buff it out with a bit less sheen, but need the thick base that can be sanded flat. Ordered a vacuum pump. Now to get th ebags, lines etc.Ohh this is that kind of thick glossy finish you'd see in an 80s Mercedes.
