Thanks ! My store here only uses that green tape..Tater, can't tell you the sizes, but I save and use a lot of the rubber bands that come with bunches of fresh produce from the grocery store (celery, broccoli, asparagus, etc.).
Thanks.. I will check out staples...The rubber bands in a bag from Staples has been quite universal for me.
Thanks... My woodcraft candy store is 80 miles away... well worth the drive.Woodcraft has a kit with ¾" wide rubber bands: WoodRiver Rubber Band Clamp Kit | Woodcraft
Thanks... is that #1 ?.. I'm doing glue up on staved an segmented bowls.. an.I use rubber bands in box making. I started with the Woodcraft package but found I was only using the largest size. More economical to get 36 of the size I used for $6.99. At Amazon
Thank You very much.... I will have to check those out..It says #107, which will stretch from 7" to about 17". About the circumference of a 1 gallon paint can with minor stretch, up to the top of a 5 gallon bucket at max stretch.
I am doing staved or segmented , an need gobs of rubber bands for glue up.. Thanks for posting..I recently replaced the windows in my house. Each 32" wide window had two rubber bands holding the cardboard packaging on. I was able to save most of them.
For a small box, I just wrapped it around 4x to hold it while the glue dried. It didn't look pretty but it worked
PM me an address and I'll send you what I have if you think you can use them. I only need one or two for myself.I am doing staved or segmented , an need gobs of rubber bands for glue up.. Thanks for posting..
Thanks for the offer, But I have a large box of #64's.. I will see if I can use them, reason for my question I see numerous people using these very narrow bands.. an wonder what they were.. plus with extreme arthritis in my hands an fingers wanting to save the stress on the fingers.. I have seen several people make these giant scissor like sticks for expanding the rubber band to fit over what ever they were making... Thanks againPM me an ass and I'll send you what I have if you think you can use them. I only need one or two for myself.
