Router Sled
Robert166
robert166
Okay I am ready to make one of these (router sled) and wanted to ask the ones here that have already done so. What would you do different? I know there a numerous plans out there and I have not decided on which one to model mine after. Thoughts?
Well, I made one before, it was nothing more than 2 long pieces of uni-strut attached to an oak frame. Then I built a sled that held the router to ride on that. That provided the X -Y travel. I used Beeswax to lubricate it. It was a little clunky TBH, but it worked.
As soon as I get settled, I am going to basically to the same thing, but instead I am going to use slide rods with linear pillow blocks and affix to carry the sled left/right (X). Then on the sled, probably will build it and use it like before for the top bottom (Y). My rationale is that the slide on the X travel should be easy, but, the Y travel needs more resistance friction to travel since it is carrying a operational router. Thinking that will help make it more manageable. I attached the set of slide rods for reference, when I got them they were about 50 bucks. I think I got them off Ebay, might have been Aliexpress
I keep thinking I need one but haven’t spent the time and money yet.
I would like to use 50x100 mm Bosch aluminum so it won’t flex.
Craig C
Craig
This was an experiment using scrap boards to build. Worked great for flattening some boards for a project. Next one I build will have some kind of chip/dust control. Very messy, which is why I did it outside.
chris_goris
I have used 2 , 4x4 x 10' fir posts jointed and planed on 2 faces, sitting on sawhorses. The sled is 60" made of plywood. Worked great. level the 4x4s in all directions at whatever spacing you need. load your workpiece on and go. I will mention, the 4x4s are hard to find and not cheap, I think they were about $35 each.
Robert166
robert166
I found a product called the “Slab Jig” from Stone Coat Countertops for $410.00
Looks interesting, same premise but different approach on the router carrier.
chris_goris
The problem with that is the wheels will run over all the shavings and the top wont be flat. Not to mention, the tabletop they claim you DONT need, you do need to make sure its level and flat.
JohnnyR
I'm pretty cheap, made this with old 3/4" ply, worked fine, need to make sure the sled is rigid enough so there's no flex. I added some more beef to the sled but don't have a picture. Learned the hard way that you have to make sure any shims under the object board stay secure. Other mistake was to overhang the L supports over the bench and they bent down. Lost a 1/2" of thickness in the process.
mpeele
michael
I use 2 2X6 I clamp to my assembly table for rails. I screw 2 pieces of 2" X 48" aluminum angle to router base.
Robert166
robert166
After reading the replies I began to search the web and found these, 48 inched long, hmmmm that could work
This is what I did. I use switchable magnet bases to keep it locked
This --- A magnetic base that is switchable. This prevents it from moving side to side if desired.
Me? I go around the entire edge 1st, the set up to go either lengthwise or crosswise, just depends on how the wood reacts. If you go crosswise and see the wood experiencing tearout, then go lengthwise. Just depends. The advantage I have is I can set the router and lock it in to position so it does not lift and if I have the magnets locking it in a fixed position, then I can just use the steel angle and pull it through. Just easier for me.
There are 2 3/4 x 3/4 square that screw down over the base that prevents it from lifting.
