Thanks, I may end up going with the straight edge/router.Getting a good straight/square edge is difficult with a small jointer or hand plane on this long a piece. If you have a long enough strait-edge, a router may be best and you don't need help. Might try Waterlox for a finish.
BLO and wax will not completely seal the surface and will require periodic maintenance. You could get a stain. I would not use that as a finish unless the recipients really want it and are prepared to maintain it.
I don't think water based finishes are less durable than oil but they are thinner. They get hard much faster. You may want more coats but the coats go on much quicker too. I'm only going by what I have read/heard. Don't think it's much less durable.
I like oil based urethane on oak more than water borne. But it is just an appearance thing. I think the yellow/amber color of the finish enhances the oak appearance.
I would make up a sample for the recipients.
Table recipients want a natural wood look for the table. I mentioned that poly is pretty durableA clear finish without a yellow tinge rules out oil based finishes like BLO, tung oil, and Waterlox (tung oil based). Zinsser ClearCoat shellac is wax free and colorless so that would be a nice finish to begin with to highlight the QSRO grain.
Durability: Water borne poly is also durable and clear. Good for a dining room table in addition to low maintenance for the recipients.
They are picking it up along with two doors I made earlier (see link). It will be loaded in three parts and assembled on site. www.ncwoodworker.net/forums/index.php?threads/barn-doors.67610/Your table top alone weighs about 207 lb. Add in the two pedestals and it's really a beast. How will you get it to the recipients in Tampa?
I have not personally had a problem but dewaxed shellac is recommended when it will be top coated. I have successfully used normal shellac, however. But if I ever have a problem I will go to the other camp. I am making a dresser now and the inside will be sheallac - it should be done tonight - and the outside will be Resisthane tinted white with Hood finishing's compatible white primer. Resisthane is advertised as a pre-cat lacquer. It is water borne. I use it un tinted too. You can get tints to add to water borne to give them the amber tint of the oil based urethane but I haven't used them. The key benefit of the water borne is drying time. I plan two coats of primer and two of top coat in a day. With my normal need to sand out a sag or two between coats that will keep me busy.
Steve, finishing is not one of my strengths but it seems that the "finish" is what most folks notice first. Over the years, I have tried various finishes but the most foolproof for me has been Danish Oil followed by multiple coats of polyurethane (first couple of poly coats are gloss followed by two or three of satin). My reasoning for saying this has been the most "foolproof" is that I have never experienced any blotching. Blotching has been a problem with stains even if I initially use a seal coat. The major drawback with Danish Oil is that even with the darker finishes (i.e., dark walnut), it really doesn't darken the wood all that much.
Thank you for asking....I am making slow progress, hopefully I will be posting some pics soon.The more I read, water based poly or clear shellac seems to be the direction I'm leaning. I still have a large lambswool applicator I used to poly a floor which turned out great, considering I'm the one that did it. Maybe since it's such a large table top that's the way to go. Used oil poly on the floor, wonder if water based will dry to fast. Maybe if I get shellac flakes and mix it thin that will work?
How's your table coming along?
If you go with water based poly, be certain that it provides the color/clarity you want on unstained wood - sometimes water based poly will be 'clear' but have a weird looking blue cast (DAHIKT!) when viewed from an angle. I have twice had this happen - most noticeable on unstained wood. Once was 20 years ago on unstained RO project (recall that clearly), and once was far more recently, but I can't recall the details (hmmm getting to that age - I do remember what I had for breakfast, because I have the same one every day).Table recipients want a natural wood look for the table. I mentioned that poly is pretty durable, oil version yellows with time and the water version seems to remain clear although it is less durable. ... Any suggestions, advice, comments?
A project like this definitely deserves a test of the finish schedule (something I know I should do, but rarely have done) before committing the final piece.
the finish will be Rubio monocoat pure.
Rubio products are interesting, plant based, and they originated in Belgium They have several colored products for the oak?
Oil Plus 2C Colors
View the 55 Rubio Monocoat Oil Plus 2C colors on 6 different species including White Oak, Red Oak, Hickory, Walnut, Pine and Maple.www.rubiomonocoatusa.com
Rubio Monocoat Products are Green | Special Hardwood
0% VOC and Eurofins Indoor Air Comfort Gold Label Rubio Monocoat Natural Oil Finish is a zero VOC non-toxic formulation. Traditional wood finishes are loaded with volatile organic compounds (VOCs) that release harmful gases into the atmosphere and can cause respiratory problems, headaches, and...www.monocoat.us
