Ripping blades for SawStop PCS 1.75hp
I've had a SawStop for the last year or so. I got the 110V, 1.75hp version with the 36 inch rip fence. I like it but I have tripped the overload a few times. Today I started a bunk bed for my grandkids which will be made of construction lumber. I bought the wood today, cut the 2x4s for the legs to rough length (7'), jointed one face of each and glued them up to make roughly 3x3 legs. After glueup, I ripped off the remaining rounded edge on one face and then cut them to rough size, 2 7/8 square. So this is what I was doing, ripping softwood roughly 3 inches thick.
I put an essentially new infinity 24 tooth full kerf ripping blade. I used both thin and thick kerf blades in my old BT3100 and never noticed much difference in power requirement and typically the full kerf left a smoother surface. But the 1.75hp sawstop definitely does not like them. The Infinity was terrible. Even with a slow feed rate I was tripping the thermal overload every couple feet. So I put on a full kerf Freud ripping blade, 24 teeth. It had been used a bunch more than the infinity but was in pretty good shape. That did OK. Sometimes I could rip 7 feet without a trip but sometimes I got one. But never more than one in 7 feet. Then for the heck of it, I put on a new cheap Irwin 24 tooth blade. I could cut as fast as I wanted with it but it left a really rough surface. I did not like that so I went back to the Freud.
I got done but I just placed an order for a Freud thin kerf ripping blade. I bought one in 2010 and liked it but the teeth are chipped from running into nails. A new one should solve my issues.
I remain unimpressed with Infinity blades. I also got a 50 tooth combination when I got the ripping blade and stopped using it. Maybe with a more powerful saw they are good blades. But not for my saw. I could do what I want to do with full kerf Freud blades but I think I will be happier if I just use thin kerf blades on it. That is what it seems to want. I did not order a thin kerf combination blade for it yet but I may. The full kerf Freud I've been using cuts well but switching back and forth between thick and thin means I should recalibrate the rip fence which is a minor hassle.
Three inches is a thick rip, no matter what saw. If it would give you enough depth, try a Diablo 7-1/4, 24 tooth blade. No your blade brake won't work, but these blades cut like a knife thru hot butter. Check the voltage at the saw, under load if possible. You could be experiencing low voltage which helps to create heat at the over load. Have your Freud thin kerf sharpened and retoothed as necessary
zdorsch
Zach
I’ve been happy with the Freud thin kerf blades on my RAS, miter saw and unisaw. Even the thin kerf Freud combo blades leave a smooth cut cross cutting. I think I’ve used 4 of the various Freud thin kerf blades a t this point.
I plan to have some of the older ones sharpened but I don’t have enough to send to Ferris yet.
The Tripping of the breaker may be due to under size wire in the wall. It might be fed by 14 ga wire
All tools should be fed by 12 ga wire if the motor rating is 12 amp or above.
Wiring is 12 gauge, it is a 20 amp circuit. But it isn't tripping the breaker, it is tripping the thermal overload on the saw. Breaker has never tripped on the Sawstop. I think the thermal overload is set conservatively. But if I can find blades it cuts well with, then I will be set. I am optomistic the Freud ripping blade will solve it and I can then decide between a full kerf combo blade for most of what I do with it and switching to a thin kerf for that too.
My biggest surprise is that the Infinity blades work so poorly on this saw. They appear to be nice blades but just won't cut on this saw. I should have just bought a couple new Freud blades when I got the saw instead of the Infinitys. Live and learn.
chris_goris
A 3" rip for that saw is probably too much for the motor to handle. Maybe try ripping 1-3/4" deep and flipping it end for end?. There are lots of factors when ripping thick materials that cause problems. think about it like this, a tablesaw is really just a big disc brake, and anyone old enough to remember drum brakes can attest to, how much better disc brakes are. The further you get from the rotational center on the disc, the less force required to stop the wheel. Now introduce things like wood binding, sap, blade width (amount material removed per second) and too much depth of cut and youre doomed.
bowman
Neal
Is it possible to change the motor wiring to 220V, assuming 220 is an option in your shop? Same total wattage, half the amps.
bowman
Neal
I was thinking it would be less current flowing that would trip the thermal overload. Just a thought, carry on
RedBeard
Burns
Have you checked for parallel between your fence and blade? It’s possible it could be binding as you push it through causing the motor to work harder.
The fence is adjusted to be parallel to the blade. The work is not binding, it is just a deep cut for a 110V saw. But it will do it with the right blade. The feed rate was not even slow with the cheap Irwin ripping blade. If I had purchased the 3hp version of the PCS I could probably do this cut with a combination blade. Certainly the Infinity ripping blade would work. But with the 1.75hp motor, I need a blade the saw likes.
I noticed the thermal overload triggered as I was cutting through knots with the Freud blade. I'm not sure that was the only time it tripped but I know that was the case one of the times.
I could have reduced the depth of cut but when I do this the two cuts tend not to line up exactly leaving me something to plane or sand off. The Irwin blade roughness would be less of an issue. It actually planned off pretty easily on the one post I used it for. I am pretty sure the Freud thin kerf ripping blade will give me the higher feed rate of the Irwin with a smoother cut.
While I was a bit surprised with which blades worked well and which did not, it was consistent with my views of 110V table saws. I believe they will do everything larger motor 220V saws will do but you have to change blades more often and the blade needs to be clean and sharp on the most challenging cuts. For the Sawstop and perhaps induction motor saws in general, thin kerf blades really do help (my old BT3100 used a universal motor (with belts to the arbor)).
Brantnative
It could be the Infinity blade. If new and it's not performing as you expect send it back. Do you see any pitch build up on the teeth? Construction lumber is probably more prone to this. I have a set of three Infinity blades I bought about 5 years ago. They're full kerf and do anything I want them to do on my Rigid 3650.
pop-pop
Man with many vises & whackers
It could also be a faulty thermal switch,
Or a motor loaded with sawdust impeding the flow of cooling air. Try blasting compressed air thru the ventilation slots, might help, and can’t hurt.
Anyone close to Jim have a Killowatt meter. With it he could check the actual current draw and voltage at the plug. Thermal over loads can and do go bad. Some are very sensitive, and trip too quickly. I would imagine this saw has a TEFC motor on it, so saw dust build up shouldn't be a problem. Could the outer fan not be turning with the shaft? When saw trips overload, is it strugggling to maintain speed? Is the body of the motor too hot to touch? You could rip slightly over sized ( + 1/16" , +1/8") using Irwin blade, then change to Freud and bring to final size. I do this a lot when ripping maple, which has a tendency to burn.
Billm0066
I have the same saw as you. I just put on a Forrest 40 tooth blade. It rips through wood amazing. It’s my first Forrest blade and so far I really like it. 3” is a deep cut. I would do it in two passes. I just ripped some 8/4 maple and it ripped through it like 1/4 plywood. No burns either.
I got my new Freud thin kerf ripping blade yesterday. I just ripped a bunch of softwood with it and it definitely works a LOT better. I was cutting 2.5 inches deep instead of the 2 7/8 I was doing when I wrote this but I am confident it would do a little deeper rip fine too. Feed rate is normal and cut is smooth. I should stop messing around with other brand blades and just stick with Freud. Other blades often work but I've never had a Freud that did not work well.
tvrgeek
Amazing what the right blade will do! I rip 3 inches of oak on my Ridgid contractor with the Diablo 24 tooth thin rip, no problem where it was a struggle with the all-in-one wonder blades. I then switch to my 60 tooth Diablo for cross cuts. Diablo and Freud are the same quality, just larger carbides on the Freud so they can be sharpened more times. Cost of a DIablo rip? Disposable. Same with Amanna and Momba. I think CMT, Ridge Carbide, and Forrest just make professional "big carbide" blades. I only go to full kerf for thin stock. All the big brands are excellent. Preferences are splitting hairs. The correct design is what matters.
++ for all the clean blade, blow out motor, perfect fence, riving knife in place etc. FWIW, I run mine on 220 and it has the perception of being a little stronger, but it is the same windings, just in series not parallel. So it should make no difference unless you are getting substantial voltage drop across too long of a run of 14 gauge wiring. My shop is all 12 or 10 gauge.
