I got this in an Ebay buy I wanted the egg beater drill and it came with this #27 plane , a skew chisel and something else.
Anyway, the drill was a good deal a 17 bucks, but all this other stuff I figured I would just toss. But, when I looked at the plane I thought ...hmm I might be able to make this work well enough to use.. Anyway, I took it apart cleaned and sanded then oiled the Beech wood body.. It looked pretty good, quite a bit of cracking, so I got some rivet head barrel nuts and bolted the sides together so it would not continue to crack. Then, got new hardware and reassembled.
Then like a dumb-ass I sliced my thumb on the freshly sharpened plane iron, not deep, just typical lame...then tested it, it actually works ok. Tricky to adjust but it does work well.
I did some checking and based onwhat I can tell this is somewhere between 1900-1920 build. That was fun to restore.
