Love it! Very creativeAnother thought came to mind if it won't make the clock hands too proud of the face. Cut a hex piece of wood to resemble the arbor nut and drill your hole in it.
Like Tom, I found something at Lowes for a similar need. I always start with Hillman or the Hillman flat boxes at the hardware stores.I got lucky at HD or Lowe’s a few months ago to find a 5/8 x 1/2 nylon bushing. Possibly chk for 1” OD. It’s off white nylon so will still need a face side washer. Several yrs ago, I found countertop hole plugs, on Amazon in small quantities, I got a 2 pack, basically a solid grommet - I used a bit of silicone under the rim to seal and adhere them. Brushed nickel finish on plastic, other finishes were available, but could be painted. Pretty sure I saw metal versions, just not sure if 1” is available but worth a check. Otherwise, I’d do like Mike and turn one.
Looks like drilling a hole smaller is akin to cutting a board longer.
The real question is: Can I use this dilemma to justify a new tool?
Instead of spreading glue with a straight edged credit, or worse trying to cut teeth into one, use a plastic serrated knife you get with take out food. The spread is uniform, and I guarantee you'll get less squeeze out.We'll have to add that to the list of uses for old credit cards. They get used for everything from spacing to spreading glue already here.
Great idea! I also have several old plastic hotel room key cards that I use for a variety of things (scraping frost off car windows when you forget your scraper, for example)Instead of spreading glue with a straight edged credit, or worse trying to cut teeth into one, use a plastic serrated knife you get with take out food. The spread is uniform, and I guarantee you'll get less squeeze out.
You've never heard of a board-stretcher?Looks like drilling a hole smaller is akin to cutting a board longer.
Just heat up a piece of threaded rod and hold one edge of the CC against it for a few secs. Voila! Instant serrations........Instead of spreading glue with a straight edged credit, or worse trying to cut teeth into one, use a plastic serrated knife you get with take out food. The spread is uniform, and I guarantee you'll get less squeeze out.
