Recent turning, like today
Dee2
Gene
About 14" in diameter
Some cherry burl:
Kubota photobombed me!
Found this in the dried pile. Turned last fall. Once turned pecan. Time for sanding. Wall thickness a little under 1/4". Shaped by nature: ~10" East to West and ~11" North to South. Looks much more oval than it measures, IMHO. So far, it will hold soup! Golf ball for proportions only.
golfdad
Co-director of Outreach
Dirk
Good looking piece Gene. Really curious how you finish turn an oval
Dee2
Gene
Dirk,
Thank you. To your question, here's the lathe mount for finishing turning:
This is a once turned bowl, i.e., 1/4" max wall thickness. Sure can't turn an inch of warpage out of that. So, there is no finish turning unless you include the "sanding gouge" going round and round.
FWIW, Zep (orange cleaner) is really helpful on Pecan. Dry 80 grit was like a buffing wheel. With the Zep, the 180 grit 'sanding gouge' did a fine job. I'll look at in a few minutes and consider 220, etc.
Dee2
Gene
Technically, I did turn it again to remove the tenon which was also oval shaped in the drying.
Above is just a friction chucking. I use a mouse pad on the inside and a Supernova with 70mm jaws on the spindle.
Tenon turned down to a nub. Checked the bottom for flatness and bring out the vacuum chuck.
Close to 27" vacuum but I don't think the gauge is real accurate.
Tenon be gone. About 5 mins start to finish with sanding. I'm a little slow. I used a 1/2" bowl gouge.
