I'm obviously in the minority. I owned a table saw and a radial arm saw at the same time for a lot of years. Used them both on an ongoing basis. When I had to downsize my physical shop size I had to decide which saw to keep. I kept my 12" Craftsman Radial Arm saw. It's now 16 years later and I don't regret that decision at all.
I rip and crosscut with it. It will do almost 16" crosscuts. It will do rips a little over 16" wide. When I 1st bought the saw (new) I modified the table adjustment rails and put jacking screws under them. The original way of loosening 4 bolts and banging around on the table with a hammer to adjust it was a exercise in futility. I also modified how the fence got locked against the table. I have some custom made, industrial quality, portable, in/out feed roller tables too.
You will be very unhappy if you don't get the table aligned properly. Same for the motor carriage. Takes me probably a couple of hours to do from scratch but once done will stay that way forever. I'd say most people don't have the patience to do it right, hence the constant frustration and hate for the RAS. Having to get about 10 measurements to coexist within .001" isn't a 10 minute job.
To go from crosscut to rip takes 30 seconds. Loosen knob, pull up on locking taper pin. Rotate carriage 90 degrees, drop pin back down. Tighten knob. Done. I don't understand why anyone would have a problem doing that.
Anybody scared of cutting off a body part with the RAS better stay away from a SCMS too. You do have to keep your hands/fingers/thumbs connected to your eyes, through your brain, at all times.
Having said all that, I'm also in the boat that says use the router for dados and rabbits. I'm fairly adept at cobbling together a router sled and or custom router fence that allows me to efficiently do dados/rabbits for a particular job. The router of choice is usually my big hitachi, 3hp, 1/2" shank, with a custom 12"x12" lexan base.
I've got a picture of a big wall cabinet in Mike's post on Sketchup and plan dimensions that I built. All cuts were done with the RAS, router, CMS, or old fashioned skills saw.
Now, if you want to talk about a dangerous stationary power tool look no further than a decent sized home metal lathe that has about a 3 to 5 HP motor. My son won't even turn mine on. Doesn't like that big spinning chuck. A 200# human body won't even slow it down.
just be comfortable and safe. If you are not comfortable doing something you also are not safe.
