I made three Oland handles 5/8 , 3/4 , and 1" and they came out real well.My question is about the face angle that you should sharpen the cutters to.I think I may have overcut the first one as it almost self feeds.Took a heavy-- inadvertant cut out of a piece I was turning.Is the cutting edge close to 90 degrees to the top edge then ground back or what.I need a little wisdom ,I also used some hot rolled steel for the handles because it was what I had on hand but the next ones may be aluminum.The 1 inch handle has no feel because of the weight.Thanx:dontknow:
