A friend is putting in a new shop - 12' x 22' - and will be pouring a concrete floor.
Before he does that he wondered about putting some dust collection tubes (I assume 4" PVC) in the floor bringing period ports up to the surface to connect to various equipment with solid and or flexible tubing. Should work well for a port coming up to the table saw in the middle of the room. He is planning on putting the dust collector outside the shop room.
If the dust collector was going to be in the corner, I was thinking he could run one tube down the long wall, one down the short wall, and one into the middle of the room.
Several questions:
- for turns in the tubing in the concrete, use the larger 90 degree turn connector or a "Y" connection (for example for the period ports along the run)?
- what kind of connector would you use at each port? Be nice to have the table saw connection to be flush with floor with a cap (screw-in?) when not using it.
An other ideas, issues or concerns with doing this?
Thanks in advance!
Dan Snyder
Several questions:
Thanks in advance!
Dan Snyder
