Proof - Goblet #1
SteveColes
As I was finishing up this goblet, I was sure it would break the stem, so I took this picture to prove I actually got this far.
Then after I made the " cleaning" cuts I was sure it break, when I parted it off, so another picture.
So after I wiped it down with MS, it looked sort of nice, so another picture.
FYI, the color showing in the picture is all wrong. To the naked eye, itlook as if I rubbed MS on Maple. Not sure why it is showing red to the camera.
So how did I think I did, not bad, but a long way to go. But I'm satisified as the first one I did from start to finish with out any help.
Turnings skills: Well, on the outside not too bad. I got the basic shape I wanted and was able to use the basic between centers tools without too much trouble if I took my time.:eusa_danc
Inside work, basic end grain hollowing, better but still need a lot of work on technique. But shaping and finshing cuts were a disaster:BangHead:. My basic problem was that I was working blind:eusa_booh. Could not see the deep sides or bottom of the goblet when trying to clean up the mess I made when doing the hollowing.:slap:
Design: well, lots of problems. I wanted the transition from the cup to the stem to be much more shallow. The transition from base to stem. Bad idea. Should have left the bead off all together.:slap: and had smooth transition. Or if I had to have the bead, it should have been embedded in to base.:slap::eusa_doh:
But all in all this was a great learning experience and a confidence builder. So it was worth it.:drunken_s:eusa_danc
I'll post a picture of it again after I apply a finish. Running color test right now.
FredP
Fred
looks pretty darn good to me!:eusa_clap the more you make the better they gits.:-D soooo..... how bout a matched set?:rolf:. congrats on the turning steve.
fred p
jeff...
User not found
Nice Steve and I bet it holds wine too... :-D
Big Mike
Steve, I think that is a wonderful goblet. In the future I would go ahead and sand and finish the inside of the bowl of the goblet before I turned the remainder. Then when you have shaped the exterior of the bowl to your liking and before you have completely thinned down the stem, sand and finish the exterior of the bowl. Then bring your tailstock up for support and cushion the bowl with some cotton cloth over a section of computer mouse pad. Then thin your stem and shape the foot and sand and finish.
I think you did a great job.:icon_thum:icon_thum That is a terrific goblet and I need a set of 8...
SteveColes
SteveColes
Actually, that's basically what I did. Just like you taught me:lol:, There is cushioning inside the cone. I just trimmed it so it wouldn't be flopping in the wind:lol: The only difference is that I did a basic outside bowl shape, so I would have something to judge the inside shape to. Even if I did it exactly like you said, I would have still had the problem of not being able to see enough of the inside to get clean cuts. and get a smooth inside bottom is still some thing I can'y figure out how to do.:BangHead:
When I do the next one, I'll try again see if I can find a technique that works for me.:roll:
Thanks, that means a lot coming from you. Now let's see, 8 x $250 = :rolf:
sapwood
Roger
8-O8-O8-O Great goblet and wonderful description of process.
Don't forget to sign it in some fashion. And let me be the first to request a Steve Coles original commission piece :eusa_pray Doubt if I could afford a goblet, but I would love to have a mallet . . . you know, one of those round whammer hammers. I'll pay in cash :icon_thum
Awe struck,
Roger
Awesome Steve, way better than that weed pot you made a while, long while ago. I have attempted a few gobblets and none have survived. They ain't easy. How much coffee does it hold? :icon_thum:icon_thum
cskipper
Cathy
Great job! I've wondered about seeing inside something like that too. Let me know when you figure it out.
Big Mike
Steve, I gather from what you are saying you are unable to judge when you have a smooth interior. When you are cutting end grain you can almost always expect some roughness from the gouge. If you have a very sharp roundnose or asymmetrical/French curve type scraper you can take very light cuts and get the inside very smooth indeed. End grain responds very well to a sharp scraper. Be sure to cut from the center out so the grain remains supported. Just remember to take light cuts and remove a little at a time. You want to stroke it with the scraper rather than scrape the wood as the tool name suggests. Properly done the end grain will be quite smooth and require only a little sanding.
JackLeg
Reggie
Hey Coles! Great looking wine glass! I'm just glad to see you actually have some time to make sawdust. I know the site keeps you hopping.
Canuck
Really, really nice work Steve!!!!:eusa_danc:eusa_danc:eusa_danc:eusa_danc:eusa_danc
....I am right smack dab in the middle of building that wine cabinet (plan I was looking for awhile ago.) for my daughter and sure could use about eight of that fine stemware to add a really classy touch to this cabinet!......
Looks like you have mastered the goblet turning!:eusa_clap:eusa_clap:eusa_clap
Thanks for all of details too!
skysharks
John Macmaster
Mr. Steve may I put in an order for a matching set for an up coming anniversary.
Fantastic Job:icon_thum:icon_thum
K Humphries
kenny
great job on the goblet man...
Just pickup my first lathe the other day but havent had much time to work with it. Maybe when I try may hand at it I will call and get some pointers.
pretty work!:icon_thum
Kenny
