Mike,While the toolmaker is half the precision of the Master it is still 5-10 times better than the others and for the price probably sufficient for your needs. I don't think you will be disappointed. Maybe ten years down the road you will look back and think 'What a bargain that would have been" but you will have ten years of accurate use and $200 invested in some other tool that you need.
You are so right... We all talk about the.. "buy once... cry once.." experience.. and I am usually onboard with that (table saw, table saw blades, track saw, TSO track saw stuff..etc.).. but why did I not continue that purchasing path when it came to my squares? :'(
I am definitely crying more than once..
With all of the squares I invested my hard earned money into.. I could have bought a 6" & 12" Starrett square :'(
That's their calibration procedure. It does provide a lot of insight as to how they actually test it.
The Bruce tool works square doesn't provide any spec and says it's adjustable - in fact they provide a method, so IMO, they're guaranteeing nothing. It's up to you to make it accurate using other equipment as a reference.
Scott.. you are right. My Bridge City squares are very similar to the Blue Spruce squares.. made to be adjusted. :\
I am going to go with that 6" Starrett Toolmaker SS square.
Not sure I'll buy a 2nd Starrett (4" or 12"), since I'll most likely want to compare the other Starrett to it.. and knowing my luck.. one of the squares will be off... Haha
Anyways... "buy once, cry once."
Thanks again..
