Porter-Cable Omnijig 7116 24" Dovetail Machine - $279
DIYGUY
This jig is in top condition and with a little TLC could be as new. P-C dropped this line years ago - it's likely because it was expensive to make, and thereby costly when compared with other brands. Many experienced WWers are familiar with the Leigh Dovetail jig. There isn't any comparison. This is iron and steel, with the only alloy being in the templets. It weighs over 25 lbs. Your work will be securely gripped when machining with it. Get a good look at what it can do with a video on YouTube from P-C back in 1989! I'm confident you will find helpful and relevant information with a search.
Included along with the standard half-blind templet (7117) is an optional adjustable through templet (7122) that lets you make any type of dovetail desired. The original instruction manual is also included.
If you buy my jig I will throw in a dovetail router bit.
