Poplar needed
bobby g
Bob
I need several hundred lineal feet of 3/4 X 3 1/2 kiln dried & pretty clear poplar or other inexpensive wood to use as baseboard in my shop and truck garage. Lengths of 12-16 feet would be ideal. It could be rough cut at 1 1/8 X 4" or 8" wide.
Thanks,
bobby g
MarkE
Not sure if you can use green, but just thought I'd through this out there:
http://raleigh.craigslist.org/mat/2174251286.html
We cut to your specs. Our saw mill can cut up to 18 inches wide and 17 ft long. prices are as follows
Pine .50 bf
Oak .75 bf
poplar .75 bf
cedar 2.00 bf
black walnut 4.00 bf
spalted hickory 4.00 bf " limited sizes"
Pine Beams are .30 bf "8in x 12in and larger"
Pine siding is 1.00 bf
If you are not sure how much a bf "board foot" is. It's a sq ft 1inch thick so a 12in wide board 1 inch thick and 10 ft long would be 10bf.
here are some examples
2x4x10ft =7.5 bf
2x6x10ft =10 bf
2x8x10ft =15 bf
4x4x10ft=13.2bf
if you would like to --------->"PLACE AN ORDER"<---------- call Tim at 919-247-1985. Please don't call and waste my time if you're not a serious buyer. The wood is green and cut to order.
  • it's NOT ok to contact this poster with services or other commercial interests
PostingID: 2174251286
MarkE
Here is another option:
http://raleigh.craigslist.org/mat/2173888653.html
I have 1st quality primed crown, base, casing and more available for delivery at a discount. I also have shoe moulding, basecap and primed mdf 1by. All moulding is new 1st grade and comes in standard lengths There is no minimum to purchase and deliveries are made on Monday to Raleigh and surrounding areas. To order or ask questions call Wayne at 980.241.2596. All orders for Monday must be confirmed by SUNDAY evening! :
Chair
3-1/2" primed chair rail at $1.25ft
5-1/4" primed chair backer at $0.99ft
CROWN
3-5/8" primed crown at $0.79ft
4-5/8" primed crown at $0.89ft
5-1/16" primed curtis crown at $0.99ft (top left)
7" prime crown $0.99ft
CASING
2-1/4" primed 356 at $0.49ft
3-1/4" primed 445 at $0.59ft (prime mdf or non prime finger joint)
3-1/2" primed RB3 at $0.79ft (prime finger joint)
5-1/4" primed window stool at $0.95ft
BASE
7-1/4" primed base at $1.25ft
5-1/4" primed base at $0.89ft
4-1/4" primed base at $0.69ft
3-1/4" primed base at $0.49ft
1/2" x 3/4" primed shoe at $0.29ft
***large orders may receive additional discounts***
***non-primed fingerjoint material available upon request***
PostingID: 2173888653
sawduster
Robert
We got poplar from saw4you when fred built my dresser. The wood was good ( according to fred )and the price was right :icon_thum
bobby g
Bob
Thanks for all of the input. I'm going to use the pre-primed MDF for the shop and the poplar for the library. I have decided to use treated in the truck garage.
bobby g
James Davis
James Davis
Bobby,
In the past I have used the cheap 1x4 treated pine in garages as baseboard. But instead of just putting it up, I tilted the table saw blade to about 15 degrees and ran the board through on edge. That way, it makes the board look bigger than it is and makes a good looking base that can take the moisture.
James
