I have jointed wide rough Ash boards on my 6” jointer, so I am left with 1/4” to 3” of the face needing jointing. The unjointed part of the board face are 1/8” proud of the jointed face.
Several videos show a simple sled, using 3/4” plywood and particleboard. You place the jointed face of the board face down on the sled, unjointed part on this side aligned with the sled edge. The board is double-sided taped to the sled.
You plane the opposite face flat in multiple passes. Then you remove the sled, flip the board, remove the double-sided tape, and plane the “unjointed edge” down to the jointed face, maybe using a few additional passes as needed.
Simple enough.
My question: are there potential issues with not using the double-sided tape? The boards are 50” and 46” long. Using a 6’ sled 1/8” depth of the unjointed part should easily ride along the edge of the sled, so the board will feed through the planer straight.
Simple enough.
