So I am experimenting with differing occasional table designs and have built a prototype in walnut and glass
The glass sits passively in a recess as seen in the pic...at least it sat passively in the recess...not so passive now as the glass is firmly wedged in the opening...the table was moved from the shop to a conditioned space a month ago and as expected the moisture content went down and changed the fit. The fit is tight in CD and AB dimensions.
We all know what they say about assumptions....but I assumed that as it dried that the change would be to make the hole slightly larger in the C-D dimension with normal contraction. I have not checked the moisture content, but would be surprised if it is not less than when the table was built.
OK wood wizards...Why is the glass firmly wedged in the hole now.
