I finished cutting and fitting the mortises and tenons and glued up the door for my shop office. It is another heavy oak door made from wood harvested on my lot (plus two boards I actually paid money for :-( :-D. ) I have decided I need to save my money to buy a shoulder or rabbeting plane if I'm going to be making any more of these big doors with large tenons.
I used a benchtop mortiser and discovered the reason my last door had some M&T problems- I have a cross slide vise on the mortiser and just noticed that the jaw faces weren't parallel vertically to the mortising bit. Luckily I noticed while cutting the first of 10 deep and wide mortises. I shimmed the vise as best I could and also made sure I reversed the stiles in the vise before cutting the opposite side of the mortise (I used a 1/2 chisel and two passes to cut the 3/4" mortises). This way the mortises might be tapered but not both angled the same way like with my last door. Ya'll following this?
The stiles and rails are solid 1 3/8" thick and the panels are 3/4" thick. I still need to make the window grids, do some sanding, mortise the hinges, stain and finish it, and buy and install the glass. The design is my own and supposed to be in the A &C/Mission style. Anyway here are two shots of the door.
