Not certain what this is
I bought a group of chisels on Fleabay (for too much)
I was particularly interested in the chisel on the left - in hopes for cleaning corners of a dovetail! (yep! as received it is a VERY thin edge and should work well when it is tuned-up.)
and this was in the lot...
I started to post this in the hand tool forum, but believe it is a wood turning tool...
Thinking it is a very creative version of a parting tool...
If you look at the groove (flute) cut into the working edges,
It looks like the Robert Sorby fluted parting tool :Fluted Parting Tool
The handle is cracked and loose, so once this is cleaned-up and back in service it will get a new handle...
Have you ever seen one of these?
Are my assumptions correct? (Is this a woodturning parting tool?)
What are your thoughts?
  • Like
Reactions: Oka
Wiley's Woodworks
Wiley
I have no idea what it is, but it's a cool looking antique. Because it is so crude in its manufacture, I'm thinking a brand new handle might destroy any antique value it might have. Instead, what about filling the handle with epoxy and just letting it seep out the crack. The brass ferrule will hide the shank filling, and you could press some sanding dust into the epoxy when it's still wet and get darn close to the repair not even being noticeable. My 2 cents, and I hope your injury recovery is progressing well.
Martin Roper
Martin
That's the famous, or infamous if you prefer, Canadian "hockey stick" cutter. It's traditional to wear a woolen cap while using it and utter unintelligible things like, "eh," and "hoser."
Obviously this is a corner chisel, to clean up the rounded edges left by the router bit. Or it's an Australian chisel for making boomerangs.
Very cool find Hank, never seen anything like it. Wonder what sort of advantage the angle gives you, and if it was for a very specific type of item to turn.
And I thought it was for cutting around corners..... as opposed to "cutting corners"........ :D
Cool find ! Hank
smallboat
smallboat
since we're in the realm of idle speculation... here's mine.
Not a turning tool but a scribe for flat stock.
Draw it along a straight edge to scribe two parallel lines, or possibly create a bead.
walnutjerry
Jerry
looks more like a small fro to me. Would be used in basket making to rive out splits.
Judging from the shape of the tang, I'd say it was a file in a former life. Maybe a bed scraper for a machine tool?
Sorby’s fluted parting tool is tapered a bit for clearance, but you indicated there is no taper to this tool.
I wonder if it could be an installation tool for splines such as you would see in the old style window screens.
smallboat
smallboat
Could be, Mike. Seems to me over the years I've had one of those "pizza cutter" tools that had a grooved rim.
