Project w/ Pics New workshop floor
creasman
For my new workshop floor I installed these 2'x2' panels from Dricore. They consist of a 1/2" layer of hard foam with 1/2" OSB on top. The idea is to make hard concrete more comfortable to stand on and also increase the R-value. I rolled on three coats of polyurethane. This is the cleanest this floor will ever be!
drw
Donn
Congratulations, you are getting close to making sawdust...as for now, the floor looks both durable and clean!
golfdad
Co-director of Outreach
Dirk
I was shone that product by a member yrs ago ...after all my stuff was in the shop. Hope it works well for you
Johnathon
J Flip
I've had this product on my radar for my eventual shop floor install for a while. How did it handle any unevenness in the concrete?
creasman
creasman
They recommend you purchase plastic shims -- one bag for every 60 panels (240 sq ft). I ended up returning all of the shims I purchased. The floor was mostly level and I didn't see the need. The tiles themselves don't interlock perfectly even in all cases. If your concrete is significantly uneven then I could see needing these.
I first saw this floor on Bob Gabor's shop. I liked the look and decided to use it on mine. I don't have any equipment on it yet. Hoping it lives up to the specs. These say they panels support 3153 lbs/sq ft. I don't have anything remotely close to that weight, but some tools concentrate a lot of weight in a few square inches.
You can feel the difference walking or standing on it. There is some give that you don't get with concrete. I have rubber mats strategically placed on the concrete in my current shop. I'm looking forward to getting rid of these. They make sweeping a pain.
Michael Mathews
Michael
Jim, I used the same product on my shop floor when I built the shop 14 years ago! The only thing I wish I would have done was color the finish a solid color. When I drop a nut, bolt, or screw, it tends to disappear into the OSB! I find it easiest to get down low with a raking light to cast a long shadow to find these little parts!
Wiley's Woodworks
Wiley
I'm unfamiliar with this product. Does it have the texture of standard OSB or is there a coating or does the adhesive cause a smooth finish like a poured epoxy finish? Is a 400+ # machine tool on 4 small--2sq" foot pads going to sink into the material over time?
creasman
creasman
@Michael Mathews I had the same thought (installing a camouflage floor), but went with clear poly anyway. My long-term goal is to install the interlocking vinyl tiles to have a waterproof floor as well. That is a future project, though.
@Wiley's Woodworks It's standard 1/2" OSB over 1/2" hard foam. Out of the box there is no finish. It's primarily used for underlayment over concrete. It's rated at 3153 lbs per sq ft. Others who have the same flooring haven't mentioned any issues with compression.
Wiley's Woodworks
Wiley
Thanks for the info Jim. I understand the benefits of the 1/2" foam--insulation and cushioning--but after that OSB is a sub-floor substance, not a final floor. Hopefully the 3 coats of polyurethane sealed it against moisture seeping in from either direction and smoothed out the surface for easier cleaning. If you can't get your shop floor clean with a brush head on a shop vac, you just created more work.
JohnnyR
I have similar floor and would also recommend a solid color. I don't see the need for waterproofing, I've spilled just about everything that's liquid and have no problems with it with only two coats of poly. The foam on the bottom of mine also has channels for any liquid to drain. What ever you do, do it before moving in or it probably won't get done.
ptt49er
Phillip
How did you work that around your exterior doors? Just raise them up an inch to meet the elevation of the OSB?
They look awesome - can't wait to watch the rest of your shop come together!
creasman
creasman
No concern with the exterior doors. The door sills rest on the concrete and are about 1-1/2" higher than the concrete floor. I have adjustable sills so you can raise/lower them as needed to fit the door. Adding this 1" floating floor was no problem. There is still at least 1/2" of clearance for the doors.
SabertoothBunny
Board of Directors, Webmaster
SabertoothBunny
How would this work for a garage with a standard door and a little bit of water coming under it from storms?
bowman
Neal
What should I do if water gets underneath the panels?
Address the source of the water first. Once resolved, allow the area to dry thoroughly. In cases of significant flooding, panels may need to be removed for inspection and drying. If the OSB has been wet for an extended period of time, the affected panels should be replaced, as swollen OSB will not return to its original thickness once it has absorbed moisture.
3153 psf works out to about 22 psi. Be sure you have wide feet on your fixed tools.
pop-pop
Man with many vises & whackers
Jim, those benches will be around a very longtime; Mike builds to last!
I followed this design and they are rugged,
However, as I weaken with age, they are a bit heavy for me so I passed them on to Jim who has immediate use for them. Sometime this winter, I plan on making a lighter pair aiming for maybe 1/2 that weight,
