New table saw outfeed + everything bench, WIP
JNCarr
My small one car+ garage shop dictates that my TS outfeed table is also my assembly, finishing, everything table. The original version included a router insert, and a kitchen mixer lift for my chop saw. It has served me well.
With the acquisition of a Rikon Midi lathe, I decided to change things up. I'll move the router table insert to the right wing (no politics here!) of my TS.
I decided to build a real workbench of glued up 2" thick hard maple. The lathe will be suspended upside down under the table and will rotate up when needed. Hence "rotisserie".
The workbench top finishes out at about ~47" x ~50" and was glued up in 4 sections. The mid section is 39-5/8" wide, and the two "wings" are about 5-5/8" wide. The midsection was initially glued up in 2x 19"+ pieces so I could fit each into my CNC to drill the dog holes. They were subsequently glued together. After the mid-section glue up the 3 pieces were taken back to the HWS for planing and sanding. They did a GREAT job for a very reasonable price. The edges were squared up and the mid-section was then cut into 2 pieces of about 10" and 37" via a track saw (thanks to Micheal Mathews for lending me the track saw).
A 1/2" slot was then hand-routed into the front of the mid-section and a portion of the sides of the wings. The same slot was cut into 3 sides of the 10" midsection cutoff. The pictures make it obvious what's going on.
As for the frame, the legs are 3 pieces of 1-1/16" x 5" hard maple. Cross members are mortise and tenon joinery.
The rotisserie shaft is 3/4" cold rolled rod (thanks to Charlie for that suggestion). I originally thought that a garage door spring would serve as the rotational aid in lifting the lathe - once into the understanding of how they are rated, it became apparent that it would not work. The design I settled on is a gas spring (almost constant force) coupled to a freely rotating arm. It nicely matches the torque requirements of the rotation. My brother-in-law, a machinist, is making the steel parts forming the arm and support.
Here are a few pictures of the progress as well as a simple animation of how the arm interacts with the base plate. Note that the last 35 degrees of rotation are completely manual, requiring a maximum of 25lbs of force to complete the rotation. Pretty easy.
Link:
JNCarr
Very cool! How did you do the animation video? That's really very helpful.
The animation was done with 3D Studio Max, a program I've been using for many, many years. I do all my CAD on it even though it has limitations to be a true CAD package (for example I cant get a dimensioned line drawing directly from it). After the frames were rendered, I put it together in Davinci Resolve - another great program,
Charlie
Charlie
Gginmdlowelvnmfytjnmfm,kvggf.
In other words, I am lost. Lol
Wilsoncb
Williemakeit
That’s a lot of maple. Did you use biscuits, dowels or dominos? Very nice design, please post pics when you get the lathe mounted.
JNCarr
It is a lot of maple. I didn't use any of those. I have a number of lengths of 80-20 aluminum extrusion that I use for top surface alignment.
The glue up was done 5 pieces at a time to allow plenty of alignment time before it sets too much.
The top was glued up in 4 sections, starting with the right wing which is 5 pieces. After those set, I used it as a "form" to begin the first of the middle pieces so that any slight bow would be exactly transferred to the new section. This way there is no mismatch at all between sections - just had to remember not to put glue between the sections! The beginning of each new section was treated the same.
