Ok my 2¢ worth - the biggest problem with these prefinished wood systems is one major issue
If you do not get all the same lot number the alignments on the seams becomes problematic. I just had to intercede for a homeowner on a floor like this. She complained the floor joints were open and not straight. Investigating, there were 3 different lot numbers on the box. Checking dimensions from each box revealed the machining was off by 1/64 to 1/32 in width. This was caused by how the machine was set up and its run. Either way, there was enough from the main lot # to fix this enough the owner was happy. Bottom line, a lot of these systems really make sense if you are doing 1000's of sqft but in a kitchen or living room, they do not save money nor offer anything more than the novelty of a new method.
