New Commission
CrealBilly
Book shelf - this one is 3' tall but customer wants it 7' tall and natural cherry instead of black.
Looks like I'll need to get my "Goth" on for this commish.
Rather morbid I must say...
bowman
Board of Directors, Webmaster
Neal
Good luck Jeff. I know you are up to the challenge.
At 7' tall, I would be more concerned of the side-side stability of having a lot of weight on the upper shelve an it tipping over sideways. Plus, the cherry has GOT to be better looking than the black...LOL
Raymond
Raymond
I would add in at least one anti-tip bracket, somewhere around the those side angle corners - just to be safe. If they use them, great, if not, at least you gave your client the chance to be safe.
CrealBilly
Oh yeah affixing to studs in the wall is a absolute must for this book shelf. I need to figure out what the angles are and the overall measurements. Make a template for the spider webs, rough out the spiderwebs with my jigsaw the use my router to finish the spider webs. Cherry burns so easy though... I'm going to need a new sharp bit and really slow router speed to pull off those spider webs.
Or I may just use my jigsaw to cut out the spider webs and call it done - since in the picture they aren't uniform anyways...
I might work in a French cleat to affix it to the studs. That way they can position it where the want.
Charles Lent
Charley
I install pieces of aluminum "French Cleats" to the back of furniture and shelving cases, When placed at the right height, it works very well, yet it easy to lift off when the need arises.
Charley
tarheelz
Dave
Experiment with that router speed question. I had been slowing down my router speed but saw burning increase! There's something of a balance between speed and feed rate (for a particular bit and wood combo) Went online and found people showing that a fast router speed allowed for increased feed rate and lower temperatures. Go figure.
NTCook
Nick
I have a love/hate relationship with cherry for this reason. I try to only work it with hand tools where possible.
What if you roughed it out with the jigsaw then finished it by hand with a carving gouge? That might add some attractive texture to each of the webs. Hard to explain how I'm seeing it in my head though.
sawman101
Bruce Swanson
Are you gonna make the shelves removable, so it can have a second function? Just another morbid thought.:gar-Bi
