new bowls
Stuart Kent
Stuart
I am working on a challenging new bowl project using post oak. The material was supplied and I was asked to use all of it with the absolute least possible waste. Here are a few images of the finished sample bowl and some process shots. Some of this material is in really poor condition - but nothing a little epoxy can't overcome! The finished bowls are 16" diameter x 6" deep.
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
attachment.php
Stuart,
Tell us a little more about the edge decoration.
What is the process? (carving, rotary tool etc.)
Do you do it on the lathe, or off?
Do you do it and remount to cut the beads or do you create the "field" and "color inside the lines?" :rolleyes:
Last, the finish in that detail seems different from the rest of the bowl, is that true or is the rest of the bowl "rubbed out to a higher finish and can you not do that with the detail you have created?
Stuart Kent
Stuart
Stuart,
I carve it with an out cannel gouge, on the lathe, using the indexer to hold it still. The rim is ebonized with iron acetate applied by hand with a small detail brush. Then the bowl is fumed with 22% ammonium hydroxide, followed by one coat of danish oil and three coats of Briwax.
OOPS!
I was so engrossed int he technical aspects - forgot to say - BEAUTIFUL work!
Roy G
Roy
Stuart, those are some large cracks in the last picture. Are you going to put some dye or filler in the epoxy? I have seen some decorative fillers, like inlace, that make the bowl almost art.
Roy G
Bear Republic
I second Hank' s comments. Amazing finishing techniques, going to have to look into those. The result are truely unique and beautiful! The rest of the blanks look like a lot fun to come.
Stuart Kent
Stuart
Roy G
I used fine mahogany dust as an additive to West System epoxy, it matches the final color very nicely. If you look at the knot in the bottom of the finished bowl it is filled.
Stuart Kent
Stuart
thanks. The first batch is 75, and then the remainder. I estimate the whole project to be about 350 bowls.
Bear Republic
Looking forward to seeing how the interesting blanks turn out and your methods of working with them. I'm sure there will be 350 beautiful bowls to follow.
Stuart Kent
Stuart
keep your fingers crossed for me - there's some tough stuff in this batch! I'll keep you posted as things progress...
Jim M.
Woody
Beautiful bowl, the rim detail is amazing, I can't imagine having to do 350 of them. Thanks too for sharing the "blank" pictures, its cool to see how a turning project starts.
Dee2
Gene
I noticed the duct tape. My experience with West epoxy is that it dissolves the duct tape 'sticky'. I've started using the aluminum tape (real "duct" tape) which seems to hold up as a barrier to migrating epoxy. You have to make sure it seals and you do have to be cautious in removing it if the wood fibers are loose (DAMHIK).
Jak3
Jacob
Really cool detail on the rim of the bowl! Beautiful!
Looks like the jigging on a pocket knife!!
Stuart Kent
Stuart
I have experienced the same, but in this case, I added so much sawdust it had the consistency of brownie mix, the duct tape merely slowed the flow.
Dee2
Gene
Regardless, the bowl is ssswwwweeeetttt.
Michael Mathews
Michael
Outstanding Stuart! I would have guessed the edge detail was done with a wood burner. But, I have to agree with your gouge technique. Just beautiful!
