Need TS info
Alan in Little Washington
Alan Schaffter
I could use a little help. I need tablesaw (cabinet, contractor, and benchtop) miter slot information for a project I'm working on.
Could you please provide the saw brand, model number, and tilt direction and the measurement from the inside of the left miter slot to the center of a standard kerf blade and the overall distance from the inside edge of one slot to the inside of the other.
Example:
Dewalt, DW745, LT, 4.875" , 10.625" (dimensions can be fractions or decimal inches)
Thanks!
ErnieM
Ernie
ShopFox W1714, right-tilt, ?, 9 27/32".
Sorry Alan - I don't have a standard kerf blade. It's 4 1/8" from the inside of the left slot to the center of my thin kerf blade (if that's any help, which it probably isn't).
Ernie
scsmith42
Scott Smith
Grizzly 0605X, 5 hp 12" cabinet saw
Left tilt blade
R edge of L slot to blade: 8.250"
R edge of L slot to L edge or R slot: 13"
I have a narrow kerf blade on the saw; however since the arbor flange is on the left side of the blade, the distance above is the same regardless of the blade width.
Makinsawdust
Robert
Delta Unisaw 36-L31X LT 5.515in and 9.9375in
Rockwell Unisaw 34-804 RT 4.146in* and 9.8125in
* Arbor and bearings have been replaced so this probably varies from the original distance.
mark2
powermatic model 63 right tilt = 4.4375 left slot to the center of blade (dewalt comb), 10" between miter slots.
now I have some adjustin to do as blade isn't as parallel as I thought:5sigh:
thanks for making me check
RayH
Ray
Delta Hybrid Model 36-714B Left Tilt
Left slot inner to kerf center - 5 11/16"
Left inner to right inner slot - 9 15/16"
